RC Release on the Microsoft Store
maisondasilva
Customer
maisondasilva avatar
Brazil
Is it also possible to submit an RC or Beta version to the Microsoft Store?
Also, I notified the Microsoft Store PMs to delete the majority of the apps that were copying your program and were fraudulent! (That was quite some time ago!)
_________________
https://maisondasilva.com.br
Microsoft MVP Windows and Devices
Re: RC Release on the Microsoft Store
I do not think that Microsoft Store has a mechanism that allows posting a different branch of software, allowing users to choose which branch they want.
Thanks for reporting the fraudulent clones!
So they basically publish two different applications to the Store, one with stable versions only and the other with beta versions too, right?
