"Keeping remote directory up to date" turns into a error: "Abnormal program termintaion"
swisssol
If I start the the "Keeping remote directory up to date" feature with the shortcut (Cmd+U), then it starts with the sync and will turn into an error: "Abnormal prgram termination".
If I transfer the files manually, then it works fine.
I also tested another server and directories, but got the same error.
Running on Windows 11 Home 64bit.
Session Log with Debug 2 level is attached.
  • winscp.log (158.83 KB, Private file)
Re: "Keeping remote directory up to date" turns into a error: "Abnormal program termintaion"
