U3 Version of WinSCP?
michael wihsboeck
it's not very hard. It is more or less only a special package format with some configuration to run the app direct from U3 compatible stick, see <invalid hyperlink removed by admin>
Greetings,
Michael
JL
Thanks! I'll check it.
I would definitely be interested as well. U3 is blowing up and i think there will be more and more demand.
Re: U3 Version?
Mat wrote:
I wonder if this ever got developed.
It's implemented already. Just waiting for the certification...
Tomm
WinSCP U3
Love it!!! One request for the next version:
Allow the path to the PuTTY executable to be a U3 package!!
Thanks for the U3 port!
Re: WinSCP U3
It's not easy to do as PuTTY binary is stored in U3 archive. Unless you run it at least once directly, it gets not extracted.
Re: WinSCP U3
My understanding is (and that's is *very* limited :wink: ), is the up3 file is just a .ZIP file with the extension changed. Could you not do an in-memory extraction? Or would this be too cumbersome/expensive (ram-wise)?
But, if no, then not.
Thanks for responding!!
Tomm
Re: WinSCP U3
But there's too much logic associated with the ZIP file, specified by included manifest file (how to restore/save settings etc.).
tenest wrote:
what about allowing the path to the putty executable be a relative path?
May be I miss something, but I do not see how this could help.
QuantumNet
I am not certain of all portable versions of putty but <invalid hyperlink removed by admin>
this version that we use extracts the putty.exe to the U3_DEVICE_EXEC_PATH when it is installed.
so if you could please incorporate this feature thank you.
It has been already... You can use environment variables in path to PuTTY.
