Duplicating failing when using sudo on login
immewnity
immewnity avatar
Chicago, IL
I've got an SFTP site set up as per the "Use sudo on Login" section of https://winscp.net/eng/docs/faq_su:
  • SFTP->SFTP server is set to sudo /usr/lib/openssh/sftp-server
  • myusername ALL=NOPASSWD: /usr/lib/openssh/sftp-server is set in sudoers
  • Additionally, authentication is via password-protected SSH key.
This works perfectly fine for most file operations; I can edit/delete/move files without issue. However, when I try and duplicate files (https://winscp.net/eng/docs/ui_duplicate), I get an error with exit status 1:
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Duplicating via local temporary copy works fine.
Am I missing something, or is this expected?
immewnity
immewnity avatar
Chicago, IL
The SFTP server does appear to support direct duplication, though:
sftp> ls *.txt
test.txt
sftp> cp test.txt test2.txt
sftp> ls
test.txt    test2.txt
(running OpenSSH_10.0p2 Debian-7+deb13u4 for context)
Re: Duplicating failing when using sudo on login
immewnity
immewnity avatar
Well, uh, it's working now – ever since running the cp command above to test copying directly in the SFTP client, I'm able to duplicate without issue. Weird!
