Abnormal program termination
rfuinua
rfuinua avatar
Ukraine
If I manually drag and drop files it works fine but if I use 'Keep remote directory up to date' I get abnormal program termination and the program crashes
This started with the last update 6.6.2 RC
rfuinua
rfuinua avatar
Ukraine
I haven't downgraded so I don't know.
It worked fine in the last version though
This seems to be an error that crops up every second or third update
Usually I just put up with it until the next update which generally fixes the problem
Re: Abnormal program termination
