Authentication Failed
I am using this:
# Path to WinSCP .NET assembly
# Session options
    HostName = "blah.com"
    UserName = "XXXXX"
    Password = "XXXXX"
    SshHostKeyFingerprint = "ecdsa-sha2-nistp256 256 xx:xx:xx etc"
try {
    # Open SFTP session
    # Upload file (local -> remote)
    $transferResult = $session.PutFiles(
        "C:\doz\", # local path (can be wildcard)
        "/New/" # remote folder or file path
    # Throw if any transfer failed
    $transferResult.Check()
finally {
    $session.Dispose()
The error I am getting is:
Exception calling "Open" with "1" argument(s): "Authentication failed.
Using username "XXXXX".
Access denied.
Authentication failed."
At C:\it.info\winscp.ps1:17 char:5
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SessionRemoteException
What I am trying to figure out is that where is the authentication failing in the process. I know the credentials are good because I can manually use them, so I have to assume it has something to do with the SshHostKeyFingerprint, so I think I need to know which key should I be using in the screen shot.
Re: Authentication Failed
It's definitely not the SshHostKeyFingerprint.
Please post session log files both from the code and from successful "manual" login with the same credentials.
crughp
The logs are easy to get from the manual login, but I am not sure where they populate from the scripted task. Can you shed some light on that for me please?
crughp
I seem to be getting an error on the script. I am not sure of the syntax and where to add that into the script. I tried a couple of different places and got this error.
Session.SessionLogPath : The term 'Session.SessionLogPath' is not recognized as the name of a cmdlet, function, script file, or operable
program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At C:\it.info\winscp.ps1:3 char:1
+ Session.SessionLogPath = "C:\it.info\script.log"
+ CategoryInfo : ObjectNotFound: (Session.SessionLogPath:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
Using username "montgomerycnty_sftp".
Access denied.
At C:\it.info\winscp.ps1:18 char:5
crughp
PS C:\Windows\system32> C:\it.info\winscp.ps1
Exception calling "Open" with "1" argument(s): "Network error: Connection to "bitbus.ttuhsc.edu" timed out."
At C:\it.info\winscp.ps1:19 char:5
The wording of the error message implies you still tried the Session.SessionLogPath, not the $session.SessionLogPath (despite your screenshot showing otherwise). Please make sure to use the $session.SessionLogPath. The Session is the class name, while the $session is the variable name in your code.
So it seems that the authentication code matches your manual login. Then it's most likely an incorrect password. Note that in PowerShell, certain characters in string literals have special meaning and need to be escaped. Notably the $ sign.
WinSCP GUI can generate a working code template for you, with all necessary escaping:
https://winscp.net/eng/docs/ui_generateurl#code
