Access is denied when setting DebugLogPath
Tony_Bedford
UK
We’ve just upgraded one of our webservices (which is on a VM Server running Windows Server 2016 that used WinSCP 5.15.7 (build 10060) to 6.5.6 (build 16502 2026-03-25) and found an interesting issue.
When the end user runs the service, they get an “Access is denied” error message being returned from the C# call. Further investigation has identified that this error is being caused by the setting of the DebugLogPath
string DebugLogfile = "D:\Logs\DebugTESTLog.txt";
session.DebugLogPath = DebugLogfile;
nb: filename has been changed for this post but is representative of the real values.
We know this access denied is not to do with the log file itself because the log file is written to this area for the old version and we get the start of a Debug logfile with the new version.
The last line that is recorded in this shorten log file (before the clean-up process) is:
[2026-05-11 11:08:46.938] [0008] Assembly path: C:\inetpub\wwwroot\[location of service]\WinSCPnet.DLL
[2026-05-11 11:08:46.938] [0008] Assembly product version: 6.5.6.0
But when an admin runs the process they get:
[2026-05-11 11:23:28.490] [0021] Assembly path: C:\inetpub\wwwroot\[location of service]\WinSCPnet.DLL
[2026-05-11 11:23:28.490] [0021] Assembly product version: 6.5.6.0
[2026-05-11 11:23:28.490] [0021] Process path: c:\windows\system32\inetsrv\w3wp.exe
[2026-05-11 11:23:28.490] [0021] Session.Open entering
When we compare the log file produced by the admin with a log file produced by the old version of WinSCP it is noticeable that the “Process path: c:\windows\system32\inetsrv\w3wp.exe” line is not in the older log file. From what I can tell, this file and directory has permission for everyone to read/execute so I am not sure what file/folder the access is being denied for.
So my questions are:
  1. What file/folder is WinSCP trying to access when setting the DebugLogPath that an access denied error could be produced? and what right are needed?
  2. Is there a solution to this problem that is NOT “don’t create the log files” or “giving every user who uses this service Admin rights” ?
  3. Is this is a bug within the latest version of WinSCP which is stopping non-admin users from setting/creating log files?
TIA
Re: Access is denied when setting DebugLogPath
When setting the Session.DebugLogPath, the WinSCP .NET assembly writes only that path, and does not access anything else. Do you have a full stacktrace?
Tony_Bedford
UK
Hi Martin
I'm not sure if this is the stack trace you are referring to, but this is what I can find from .NET. I've also attached the full DebugLog files (with some redactions) that are produced when both a normal user and an admin user runs the process.
I've set these debug log files to use the Debug2 level setting, in the hope that this will yield a clue to this bizarre issue. BTW it doesn't matter which log level we use the process still fails for the normal users.
[Lightweight Function]
System.ServiceModel.dll!System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(object instance, object[] inputs, out object[] outputs)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(ref System.ServiceModel.Dispatcher.MessageRpc rpc)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(ref System.ServiceModel.Dispatcher.MessageRpc rpc)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(ref System.ServiceModel.Dispatcher.MessageRpc rpc)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.MessageRpc.Process(bool isOperationContextSet)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(System.ServiceModel.Channels.RequestContext request, bool cleanThread, System.ServiceModel.OperationContext currentOperationContext)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(System.ServiceModel.Channels.RequestContext request, System.ServiceModel.OperationContext currentOperationContext)
System.ServiceModel.dll!System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(System.IAsyncResult result)
System.ServiceModel.Internals.dll!System.Runtime.ActionItem.DefaultActionItem.TraceAndInvoke()
System.ServiceModel.Internals.dll!System.Runtime.ActionItem.CallbackHelper.InvokeWithoutContext(object state)
System.ServiceModel.Internals.dll!System.Runtime.IOThreadScheduler.ScheduledOverlapped.IOCallback(uint errorCode, uint numBytes, System.Threading.NativeOverlapped* nativeOverlapped)
System.ServiceModel.Internals.dll!System.Runtime.Fx.IOCompletionThunk.UnhandledExceptionFrame(uint error, uint bytesRead, System.Threading.NativeOverlapped* nativeOverlapped)
mscorlib.dll!System.Threading._IOCompletionCallback.PerformIOCompletionCallback(uint errorCode, uint numBytes, System.Threading.NativeOverlapped* pOVERLAP)
[Native to Managed Transition]
Description: Debug Log produced when an admin user runs the process.
Description: Debug Log produced when a normal user runs the process.
Thanks. Though there's nothing about WinSCP in this stack trace. How did you collect/find it? How do you capture/log the exception?
Tony_Bedford
UK
Hi Martin
I've tried a different stack trace and this is what I got when it errors.
Access is denied
   at System.Diagnostics.ProcessManager.OpenProcess(Int32 processId, Int32 access, Boolean throwIfExited)
   at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
   at System.Diagnostics.NtProcessManager.GetFirstModuleInfo(Int32 processId)
   at System.Diagnostics.Process.get_MainModule()
   at WinSCP.Logger.GetProcessPath()
   at WinSCP.Logger.WriteEnvironmentInfo()
   at WinSCP.Logger.SetLogPath(String value)
   at WinSCP.Session.set_DebugLogPath(String value)
   at [ABCDE]Service.[ABCDE].[ABCDE](DateTime RunDate, String& SumFile, List`1& msgs)
Hope this is of more help
