No option to bring back transfers panel to foreground, once sent to background
hoodafukisalice
Somewhere in the underground levels of S4, Groom Lake
Hello, I'm using the Commander interface option. There seems to be no option to bring the transfers panel back to the foreground (as a modal window), once it has been sent to background.
Thanks and cheers.
WinSCP version: 6.6.1 beta (Build: 17216 2026-01-01)
OS version: Windows 25H2 (OS Build: 26200.8246)
Re: No option to bring back transfers panel to foreground, once sent to background
If by "background" you mean the transfer queue, then indeed, there's no option for that. What's your use case?
