Unable to connect to SSH-2.0-dropbear_2020.80 since WinSCP 6.3.7
snowberry
UK
I've been unable to connect to SSH-2.0-dropbear_2020.80 since WinSCP 6.3.7 – this is running on a modified Huawei router. Every version since 6.3.7 fails. I've tried modifying several settings in the connection config to get it working, but I'm not an SSH expert.
Attached are a log of a successful connection using 6.3.7, followed by a failed connection attempt using 6.5.6.
Hoping someone can point me in the right direction as I'd rather use the latest version of WinSCP.
Re: Unable to connect to SSH-2.0-dropbear_2020.80 since WinSCP 6.3.7
Thanks for your report. So was 6.3.8 really the first version that does not work anymore? It does not look like there was any change in 6.3.8 that might have caused it. Can you post its log file?
snowberry
UK
Thanks for the reply. I should have worked through the versions to find where the problem started - I jumped versions so 'assumed' it was from 6.3.7.
I've now done that - the version where it stopped connecting is 6.4.2 Beta onwards. 6.4.1 Beta connects fine. Debug2 log attached.
