Disconnections after a short period of ACTIVITY
martin@eastdevon.it
UK
There are quite a few posts about disconnections, but nothing I could pin down to the issue I'm having and certainly no solutions.
This is not an idle timeout issue. I can remain connected without any activity for a long time, but when I try to execute something like delete folder - something a bit more than just a single file, during that activity,I get disconnected after only maybe 20 seconds. As a result, I can never complete the activity as reconnecting seems to start the task again.
The only way I can use this is to break it down into really small chunks, which is unworkable.
I'd love to use it more, but I can't.
I appreciate all responses trying to help.
M
Re: Disconnections after a short period of ACTIVITY
Also, do you have this problem with other clients using the same protocol? If not, can you post a log from the other client?
