Access problem
acrozz
fr
Access problem
Hi, I can't connect after uploading a lot of files. Connection refused every time, even after waiting and even uninstalling and reinstalling. The code is correct.
Re: Access problem
Can you connect with any other client using the same protocol and connection details? If you can, please post session log files both from WinSCP and the other client.
If you cannot connect with any client, please contact your server or network administrator or check your firewall settings.
