The remote file has been changed...
Bill_Fields
Portland, OR
Using WinSCP 6.5.5 with "Explorer" interface on Windows 11 Enterprise 23H2.
I have two remote sessions open, and I'm using NP++ to edit a text file from HostB. If WinSCP has the tab from HostA selected and I save a change to the file on HostB, I get the following message:
Confirm
The remote file has been changed while you were editing it. Do you want to overwrite it anyway?
OK Cancel Help
This happens every time. If the tab for HostB is selected, there's no message when I save the file. Not a serious issue that I can see, but it is bothersome.
This is a typical scenario for me (editing a file on one remote host while I'm looking at other remote hosts), so I have to say that it started happening with v6.5.5.
Thanks.
Re: The remote file has been changed...
Thanks for your report. Though I cannot reproduce the problem.
Please start WinSCP with /applog=C:\some\path\app.log command line parameter, enable also session logging, reproduce the problem, and post both app and session logs.
Re: Logs attached
@Bill_Fields: It looks like you are editing the same file on two different servers. And you have enabled option "Keep temporary copies of remote files in deterministic paths", but not "Append session name to temporary path". With that combination, the two files are saved to the same local temporary path, overwriting one another, causing havoc.
Try enabling "Append session name to temporary path", it should resolve your problem. If not, please post new logs (and please try to reproduce the problem with as little opened sessions as possible).
Re: Logs attached
Sorry, you are indeed right.
Isn't it possible that you has multiple sessions to orbdb-orbdb-rep opened?
Bill_Fields
Portland, OR
Re: Logs attached
It was possible, but unlikely.
I captured a new set of logs, with just 3 sessions open. Please see attached.
  • logs_3-3-26.zip (60.92 KB, Private file)
Bill_Fields
Re: Logs attached
I would like to add that the prompt to save does actually work on the right file under the right host. So, as long as I pay attention to what I'm saving, the end result is correct.
Thank you so much for this great tool.
