6.6 Beta - Synchronise > Transfer Settings > Exclude Directories makes sound and is ignored
jnmills
Using 6.6 Beta (build 17087) Windows 11.
If I select Synchronise, Transfer Settings, Exclude Directories I get a "bong" noise and nothing happens. Actually any menu selection off "Transfer Settings" does this as does selecting off the "OK" button menu in the synchronise popup.
The subsequent Synchronise operates on everything.
jnmills
Re: 6.6 Beta - Synchronise > Transfer Settings > Exclude Directories makes sound and is ignored
Recent post about 6.6.1 shows this has been addressed. WinSCP window was on non primary screen to the left of the primary. Moving it to the primary restored functionality! Thanks.
