An excellent program, but I did not find in the menu how to disconnect from the server.
Juri
United Kingdom
You can exit, but you won’t be able to disconnect.
In addition, it is desirable (as in wincmd) in the upper right corner of the window \.. I.e. to the root and go higher
Juri
Yes, of course it is possible, but it will take a long time...
1.I meant some button or menu item to disable
2.In wincmd, in the upper right corner of the displayed folder there are icons for going to the root and one level higher, but you don’t. Only in the left corner one level up. Also good, but unusual
Juri
It would also be nice to connect an external editor
to view and edit files. for example Notepad++ or another
Yours is good, but habits are stronger than reason :)
Re: Yes, of course it is possible, but it will take a long time...
Sorry, I do not follow. What takes long time? Clicking the X button on the tab?
WinSCP has the same buttons. See the yellow folder icons with angled left/upward arrow and slash above both panels.
https://winscp.net/eng/data/media/screenshots/commander.png
You can configure any external editor you like.
https://winscp.net/eng/docs/integration_editor
