WinSCP 3.82 - german language file
regenpfeifer
Hello, thank you for the new version 3.82. Everything seems to worlk fine, I am just experiencing a small bug apparently in the german language file 'WinSCP3.de':
When I open WinSCP in "Norton Commander"-mode, the column headers of the two explorer windows have senseless labels (instead of "Name, Größe, Typ..." it has "Filesystem Operation, V:*?,...).
Surely this can easily be fixed. I looked into the 'WinSCP3.de', but the file format made it quite difficult to find the problem strings.
Yours, Hermann J. Eckl
Re: WinSCP 3.82 - german language file
Thanks for letting me know. Fixed "multilanguage installation file" was released. Please reinstall.
regenpfeifer
Hello, thank you for your prompt answer and the immediate fix of the problem. WinSCP is a really fine and very useful piece of software.
