Right click stoped working in latest update (v6.6 beta)
theoxskyl
Greece
After updating to the latest version v6.6 beta, all right click menu items in local and remote panels, just close the popup. No actions are triggered.
Tested on Windows 10 Pro and Windows 11 Pro installations with all updates applied.
Thank you.
Description: Video capture of the issue
Re: Right click stoped working in latest update (v6.6 beta)
It might be this bug, which will be fixed in upcoming 6.6.1:
Bug fix: Some menus were not working on displays to the left or above the primary display.
https://winscp.net/eng/docs/history?a=6.6.1
