Deleted local directory causes winscp 2.3 to close
guest
Since the last time I used winscp I renamed the "local" directory. When I tried to start the application, the program complained about the missing directory andf promptly exited without allowing me the opportunity to enter the new path.
Re: Deleted local directory causes winscp 2.3 to close
Thanks, I'll fix it in next release. Solution for you is to delete a reference to missing directory on "Directories" tab of login dialog (load your stored session first).
