An error appears when trying to open the properties of files or folders.
tefu
Since around February this year, I have been connecting to and using Wasabi with version 6.3.6 via the S3 protocol. Recently, I noticed that when I try to open the properties of a file or folder, the following error appears, preventing me from opening the properties. (This error did not occur until this summer, and there were no problems.)
Title: Error
Message: Unexpected response to AWS request (Tagging).
I also contacted Wasabi, but they could not identify the issue. After that, I noticed that the behavior differs depending on the WinSCP version.
ver.6.3.6: Cannot open properties due to error *
ver.6.3.7: Can open properties
ver.6.5.5: Cannot open properties due to error
*However, if you upgrade to 6.3.7 once and then revert back to 6.3.6, you are able to open properties.
Environment:
OS: Windows 11 Pro
Protocol: S3 (connected to Wasabi)
Using GUI (Explorer mode)
Please tell me how I can avoid this error.
  • log.zip (111.46 KB, Private file)
Description: log(6.3.7 and 6.5.5)
Re: An error appears when trying to open the properties of files or folders.
Thanks for your report. Though, did you post the right log files? I do not see the "Unexpected response to AWS request" in any of them.
tefu
Sorry for the late reply.
Since the language setting when acquiring the log was Japanese, the log was also output in Japanese.
File: 6.5.5_232xxxxxx93ELKHORDG9@s3.ap-northeast-1.amazonaws.com.log
Line 702
* 2025-12-07 14:42:08.747 (Exception) AWS リクエスト (Tagging) に対する応答が不正です。
If the language setting is English, it will appear as "Unexpected response to AWS request (Tagging.)" as shown in the screenshot I sent.
※ Would you like me to re-acquire the log in English?
Thanks. The server response to "tags" query misses namespace:
<Tagging><TagSet></TagSet></Tagging>
A correct response (as sent by AWS) is:
<Tagging xmlns="http://s3.amazonaws.com/doc/2006-03-01/"><TagSet/></Tagging>
I do not know why it works for you in some versions. It can actually be random to some degree. The 6.3.7 log you have posted does not even include the "tags" query. If you want us to investigate further, please post log that actually shows it.
tefu
Thank you for your reply.
I've noticed that Wasabi is returning different responses than AWS, so I'm contacting Wasabi.
The reason this doesn't happen in 6.3.7 seems to be because the tagging feature wasn't implemented in that version.
Issue 2353 – Display and modify S3 file/object tags
If the Wasabi response isn't fixed, is there a setting in the latest version of WinSCP to disable tagging?
