Files and folders are removed from remote directory when I use get -delete
PK
Australia
I am having trouble getting files and deleting them from the server. When I do so, If the server directories are empty, they are being deleted as well. I was using a dummy file to prevent the directory being deleted, but the company has now put in place a rule to delete all files over 30 days old, so I can no longer use dummy files.
The command I am using is:
"lcd ""C:\Target\Dir\Temp_Download""" ^
"get ""/RootDir/*"" -delete -resume -preservetime -filemask=*.dat ""C:\Target\Dir\Temp_Download\""" ^
I am using a batch file to run WinSCP.
Can anyone please help me,
Thank you
Peter
Re: Files and folders are removed from remote directory when I use get -delete
Your script looks good. It should not delete the folder. Isn't it server's behaviour that it deletes empty folders automatically?
If you do not think so and still believe it's WinSCP that is deleting the folder, please attach a full session log file.
