Changing remote VMS directory issue/transferring file from local win11 computer to remote VMS issue
nzeng
USA
I started to use WinSCP to transfer files between my Windows computer and remote. I encountered two issues:
  1. on the panel for remote VMS system, changing directories worked for some directories, but failed for some other directories.
  2. I can transfer file from remote VMS system to local PC, but failed to transfer file from local PC to remote VMS system.
Please refer to the attached document for error messages. I played with WinSCP settings for hours, but no luck so far. Any help would be appreciated.
Thanks,
Nan
Re: Changing remote VMS directory issue/transferring file from local win11 computer to remote VMS issue
Though note that in general, support for VMS is limited.
nzeng
USA
Hi Martin,
Thanks for your reply. Attached please find the log. You can go to line 519 and line 615 to see the directory changing issue and the file transfer (from local to VMS) issue.
Best,
Nan
  • eprom-eprom@vax.log (107.14 KB, Private file)
Description: around line 519 and 615...
nzeng
USA
The version of WinSCP is 6.5.4 (Build 16408 2025-10-16).
thanks,
Nan
