Automatization of server synchronisation with OTP
joggel
I want to move data from a server to my local machine (and vise versa) in an automatic way. Every time if there is a new file created in a certain folder of the server, it should be moved (or copy and deleted) to the local machine. My suggestion is to have a script running on my local machine with a infinity loop, which checks if there is anything new on the server every 5 min and than do the movement stuff. The problem is, that I have to use 2FA to connect to my server. Is there any possibility to login to the server once a day with a OTP and than use the established connection? I tried a bit around with scripting and the .NET assembly but nothing worked.
Thansk a lot for your help and best regards,
Johannes
Re: Automatization of server synchronisation with OTP
How does the server prompt for the OTP? Is it a regular password prompt? Or is it an additional prompt (after password)?
joggel
First it asks for the OTP, then for the password, so there are two prompts in succession. How can I differ between a regular and a additional prompt?
Thanks a lot
