Program not saving settings?
I don't know if I'm doing something wrong or not, but the program does not seem to save any changes I do to it, like changing local directory or anything... Just goes back to default, any way I can fix this? I'm using latest version on WinXP...
Re: Program not saving settings?
Have you saved your session settings on "Stored sessions" tab of login dialog? Alternatively you can save settings of current opened session from "Session" menu.
