"Upload successful, but an error occurred while setting permissions/timestamp."
TB
WinSCP Version: 5.21.3
OS: Windows Server 2012
Protocol: SFTP
Host: sftpgw.allianz.com
Port: 9122
Problem Description:
When putting a file, I received the error
I unchecked the "Preserve timestamp" checkbox, but the same error occurred.
What I tried:
  • Unchecked the "Save timestamp" checkbox in the forwarding settings rule for the target login settings.
Log excerpt:
  • Checkbox checked
    < 2025-10-29 11:32:12.234 Script: File '20251028_20251029112528.csv' was successfully uploaded, but an error occurred while setting permissions/timestamp.
    < 2025-10-29 11:32:12.234 If the issue persists, disable permission settings and timestamp settings, or set your system to ignore permission setting errors.
  • Checkbox unchecked
    * 2025-10-30 12:47:45.340 (ESkipFile) **The file '20251029_20251030124033.csv' was uploaded successfully, but an error occurred while setting permissions/timestamp.**
    * 2025-10-30 12:47:45.340 If the issue persists, disable permission settings and timestamp settings, or set your account to ignore permission setting errors.
What do I need to know:
Please tell me what steps I need to take to avoid this error and successfully transfer the file.
Re: "Upload successful, but an error occurred while setting permissions/timestamp."
Also, I do not understand what you mean by ""Save timestamp" checkbox in the forwarding settings rule". What "Save timestamp" checkbox? What "forwarding settings rule"? There are no such options in WinSCP.
TB
This is a mistranslation by Google Translate; the correct translation is
Unchecked the "Preserve timestamp" checkbox in the transfer settings dialog for the specific uploading session.
We are currently checking if generating the session log file is possible.
There's no "Upload successful, but an error occurred while setting permissions/timestamp" error in the log.
Though there's another error, "The message ... is not extractable!", which is specific to your proprietary server and has probably similar root cause.
The log shows that timestamp preserving is on. Note that the log is from scripting running from some automation service. So your GUI configuration from user session has likely no effect on it.
See https://winscp.net/eng/docs/message_preserve_time_perm#scripting
