Synchronize does not work on Win2025
Elwood
Any problem on Win2025, even with WinSCP 6.5.4?
I use the same script I used on several servers 2019 or 2022. It does:
WinSCP.com /command "option batch continue" "option confirm off" "open ftp://login:pass;x-utf=1@ftp.ftp.fr" "synchronize local -delete \mydir /remotedir -filemask=|.stfolder/;.stversions/ -resumesupport=500" exit
Only on Win2025, both with WinSCP.com or WinSCP.exe GUI, it doesn't synchronize an existing file that was changed. It synchronizes/download new files or it deletes local files. But with a file that is present on both side, if I update the local copy, it is not overwritten by WinSCP. No error, the command line just say "Nothing to synchronize".
I never had such problem on Windows 2022 so it might be something new on 2025.
Any hint?
Thanks.
Re: Synchronize does not work on Win2025
Please attach a full session log file showing the problem. And give us a name of a file you believe should have been synchronized, but was not.
Elwood
Ok.
Attached.
File is Verif-reboot.bat (just an example as it does the same for other files if I change them)
Side note: when I use debuglevel=2, the log includes the full credentials in a "Parameter" line.
This should be avoided IMO, as the command line help says "add * to enable password logging" and I did not include "*" ;-)
Note: if required, I can provide a Windows 2025 VM for you to test.
Elwood
Strange as I use exactly the same commands on previous Windows and it always worked. :-(
Ok, I'll use "mirror" option.
Thanks.
Elwood
I never use the GUI.
But I most probably used it once at the very beginning and I then used the script generated by the GUI. That may explains.
Thanks.
