FIND command finds nothing
bugreporter12345
See photo.
Version 6.5.3
Using the Internal Editor
'Find' command (CTRL+F), searching for any word that is clearly present in the text file. Match Whole World Only and Match Case are both UNSELECTED, so it should find any instance of the search term 'CONFIG' in the file, which is present over 100 times.
Re: FIND command finds nothing
Where is the caret? You have selected search Direction Up. So if the caret is at the beginning, it cannot find anything.
