Wildcard %year% or %month% is not expanded/ignored
KlausKoeppen
Germany, Dornhan
I use a small batch for automatic backups. The source (to be backuped) is stored for each month in an separate destination folder. The name is (for example : September) : Month_09
With this line (from my batch) I try to build the name of the current month, but it doesnlt work.
  "open sftp://u..:xxxx.your-storagebox.de -hostkey=....,,,,," ^
  "synchronize remote -delete c:\SRC_Backup /Monatssicherungen/Monat_%month%" ^
The wildcard %month% is totally ignored, Monat_ is used as destination.
The same is with %year%
What is wrong?
Best regards Klaus
