- AnIdeaForBusiness
- 8
- Switzerland
Connect WinSCP to MinIO help 2025
Hi, I'm try to connect WinSCP to MinIO but not work. I have set custom region I have change to path url but still not work.
Site Admin -
- 43,224
- Prague, Czechia
Re: Connect WinSCP to MinIO help 2025
- AnIdeaForBusiness
- 8
- Switzerland
Hi, thx for the answer, my MiNio is deployed on the server with coolify under traefik proxy. Is it possible to exclude port from the URI request? Because traefik handle port automatically. Idk if is related.
Or what you suggest?
Site Admin -
Can you connect to the server using any other S3 client? Can you post its log?
- AnIdeaForBusiness
- 8
- Switzerland
This is with Cloudflare R2.
Site Admin -
Thanks. Though, I was asking if "can connect to the [same] server using any other S3 client?" Not if you can connect with WinSCP to another S3 server.
I can connect to my s3 via n8n for automations or using minio console or minio cmd.
In n8n normally I need to remove the port from address, and force path.
Site Admin -
Thanks. So can you please post a log from minio cmd?
Which log? I don't understand.
Site Admin -
Log from "minio cmd" – I assume it must be also be able to do logging, or isn't it?
- AnIdeaForBusiness
- 8
- Switzerland
I don't understand how is useful a log with witch info I don't have a log with connection info!? The issue is on WinSCP I say to you the possible solutions (remove the port from connection url). WinSCP don't reach the server.
I have no issue with n8n to connect to the server and they use path and not put or force port on the url.
- AnIdeaForBusiness
- 8
- Switzerland
If I try with 8080 port return
PS: I have a reverse proxy (traefik) so we don't need to add the port if I add the port the server is unreachable.XMLparse error
I have solved using the port 443 now I can connect to the minio server.
