Synchronization file time incorrect
magicguru
UK
if you synchronize files through the GUI, the time of the file is correct on the destination, however if you synchronize files through a script the time of the file is incorrect when it downloaded from the SFTP – it is UTC – preservetime and criteria have been set to try to alleviate this but the issue still persists
synchronize local -preservetime -criteria=<none>
Re: Synchronization file time incorrect
Please post session log files both from GUI and script showing synchronization of the same file with different results.
Btw, it's -criteria=none, not -criteria=<none>.
magicguru
UK
Script
synchronize local -delete -preservetime -criteria=none C:\ABC_TestFolder\ /TO_RSW/TestFolder
You have explicitly asked for the different behaviour in your script using:
open ... -rawsettings ConsiderDST=0
Just remove the -rawsettings ConsiderDST=0.
Then you must have the "Adjust remote timestamp with DST" configured in the GUI at the time you have generated the code.
But now your GUI session has the default "Adjust remote timestamp to local conventions" selected.
If you have a different experience, please post some screenshots documenting that.
