Keep disconnecting from FTP
abd1111
Hello! I have had this issue before, and it happens randomly (especially when I need to do some file uploads). I will often get a timeout or something like:
Exception calling "Open" with
"1" argument(s): "Connection failed.
Connection failed."
Here's a snippet of the setup:
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "usxxxxxxxxxx.sharefileftp.com"
    UserName = "xxxxxxxxxxx"
    Password = $plainPass # Read in as a secure string
    FtpSecure = [WinSCP.FtpSecure]::Implicit
    Timeout = New-TimeSpan -Seconds 150
Remove-Item $sessionLog_File
$session.SessionLogPath = $sessionLog_File
All the rest of the code is just looping through directories and doing a bunch of PutFiles. It's a 50/50 shot, usually that it won't time out halfway through my file upload list or just after logging in.
I have already tried adding something like:
$session.Timeout = New-TimeSpan -Seconds 500
below the $sessions.Open, but I don't think anything has exactly worked better.
Thanks!
abd1111
Wondering, also, if session.ReconnectTime
needs to be called in order to work, or is it just on by default? I'd love something that could force re-connect. Thanks. Not terribly PowerShell savvy.
abd1111
Here's a snippet with the same settings where it tries listing the first directory and then just stops in another log:
> 2025-08-20 15:18:12.849 Script: ls -- "/1 xxxxx CLIENTS/xxxxxxxx/Sydney TPA/A-CAP/Client Folders/xxxxxxxx/"
. 2025-08-20 15:18:12.849 Retrieving directory listing...
> 2025-08-20 15:18:12.849 CWD /1 xxxx CLIENTS/xxxxxx/Sydney TPA/A-CAP/Client Folders/xxxxxxxxxxxx
. 2025-08-20 15:20:42.155 Timeout detected. (control connection)
. 2025-08-20 15:20:42.155 Could not retrieve directory listing.
. 2025-08-20 15:20:42.164 Retry interval expired, will not retry transfer
< 2025-08-20 15:20:42.171 Script: Lost connection.
< 2025-08-20 15:20:42.171 Timeout detected. (control connection)
< 2025-08-20 15:20:42.171 Could not retrieve directory listing.
< 2025-08-20 15:20:42.171 Error listing directory '/1 xxxxx CLIENTS/xxxxx/Sydney TPA/A-CAP/Client Folders/xxxxxxx'.
Re: Keep disconnecting from FTP
The server just seems to stop responding. I do not know what to suggest.
Did you try another FTP client? Does it work reliably with the server?
abd1111
That's kind of what I am feeling. It just abruptly stops without warning. Yes, other ones are hit or miss, too, depending on time of day. Might just be them. I also notice it behave the same on the GUI doing manual transfers.
