Navigating Datasets on IBM Host does not work
Reth
Hi everyone,
currently trying to access datasets on IBM Host via WinSCP (GUI and .com). Unfortunately this does not work. So when I login and do something like navigating on UI or via cd to any dataset in the form of: XZ.....Z.S55.....ARCH. it works fine. But as soon as I try it a second time I always get the error:
An error occurred while viewing the directory "/'XZ.....Z.S55......ARCH.'".
Unable to retrieve directory contents
What is the problem here? Cannot use Filezilla (which works always fine) since I need some automation. ftp.exe is also not an option since I need automation and script support.
Any idea on how to tackle this?
Thank you in advance for your help and
Kind Regards
Reth
Seems I found at least one hint:
When I delete the application data by using the UI built in tool for deleting them in between 2 calls of WinSCP.com then it works everytime. So it seems it is somehow related to the application data which is getting stored when executing WinSCP.com.
Reth
Sorry for mass posting – do not (yet) have an account here.
Applying the parameter /ini=nul seems to work though.
Re: Navigating Datasets on IBM Host does not work
By "second time", do you mean the you enter and leave the directory. Or when you connect the second time?
