Search/Replace dialog box changes location as WinSCP scrolls through matches
crobinuk
I regularly use Search (and/or Search/Replace) to find multiple occurences of a string in a file and have noticed that WinSCP will change the location of the dialog box as I cycle through the matches.
This is frustrating if you're using a mouse to click the Next button because suddenly the x/y co-ordinates of the dialog have changed and you have to hunt for the box to continue.
Can't think of any other native Windows apps where this happens for a Find/Replace, dialog box usually stays in the same x/y co-ords when you cycle through matches?
Would be amazing if this could be fixed in a future update. :)
Re: Search/Replace dialog box changes location as WinSCP scrolls through matches
Thanks for your suggestion.
We will see, if more people ask for this.
Btw, the location is changed, so that the box does not obscure the found text.
