Change default md5sums to md5sum for Checksum command in Properties
adroman
Dear WinSCP Community,
I'm using WinSCP 6.5.3 on Windows 10 with default settings. When calculating checksums via Properties > Checksum, the embedded command uses md5sums, which fails on Linux hosts with the error:
Command 'md5sums "filename"'
failed with return code 127 and error message:
-bash: line 9: md5sums: command not found
This happens because most Linux distributions provide md5sum instead of md5sums. I can create a custom command using md5sum, which works fine, but it doesn't integrate with the Properties > Checksum feature.
Is there a way to configure or override the embedded md5sums command to use md5sum in the Properties > Checksum menu? Alternatively, could this be considered as a feature request to allow customization of the checksum command or support for md5sum by default?
Thank you for your help!
Re: Change default md5sums to md5sum for Checksum command in Properties
I have fixed this.
Also the next version will allow configuring the checksum commands:
Issue 2394 – Allow configuring checksum commands
You can actually use md5sum even with the current version by typing "md5sum" to the Algorithm box.
adroman
Thank you very much, it works fine with portable version. But could you please clarify where to find Algorithm box
