Session.Open Timeout Issue
lloftus
The following code snippet will timeout while trying to open the session with our vendor. We have confirmed via Wireshark that their server will see the initial request but nothing after that.
There is more code after the Session.Open but I have not included it in the snippet as it never gets to run due.
# Load WinSCP .NET assembly
# Set up session options
    HostName = "sftp21-cmh.sumtotalsystems.com"
    UserName = "cust_mmm_Dozuki"
    Password = "YVCbf-X0"
    SshHostKeyFingerprint = "ssh-rsa 2048 k8L86hrEaiZl+v/f+Wu1Lo/lgNuqkcWZqSi/iF1iKzl"
$session.SessionLogPath = "C:\Dozuki_Files\Scripts\_automatedScripts\winscp.log.txt"
try
    # Connect
finally
    $session.Dispose()
Description: Log file from 7/17/2025
Re: Session.Open Timeout Issue
Can you connect with WinSCP GUI or with any other SFTP client? (running on the same local machine).
If you can, please post its log file too.
Re: Open Call in Powershell not working
And can you connect with any other SFTP client? (i.e. does your SFTP server work at all?)
