Script ERRORLEVEL not working as expexted
ericcao
canada
We are trying to transfer some files to client FTP server and it needs to stop transfer whenever it detects an error (client FTP server is not stable).
We use a batch script like this:
cd /d %~dp0
".\WinSCP\WinSCP.exe" /script=.\FTP_Outbound.txt /log=.\FTP_Outbound_log.txt /logsize=5*10M
if %ERRORLEVEL% NEQ 0 (
    echo WinSCP transfer failed. Files will not be moved.
    exit /b %ERRORLEVEL%
cd /d D:\Exports\
rem Move files to Backup folder:
move /Y *.* Backup
We are trying to exit the script completely if the ERRORLEVEL is not equal to 0 but it never work as expected. Please advise.
In the logs we can see errors like
Connection failed.
which might not return as ERRORLEVEL other than 0 I assume?
Thanks and appreciate your help!
ericcao
canada
Re: Script ERRORLEVEL not working as expexted
Thanks. Please see attached log. Client FTP server is constantly lost connection and it is not returning error code 1:
. 2025-07-31 02:17:54.795 --------------------------------------------------------------------------
. 2025-07-31 02:17:54.796 Connecting to ingest.example.ca ...
. 2025-07-31 02:18:09.808 Timeout detected. (control connection)
. 2025-07-31 02:18:09.808 Connection failed.
. 2025-07-31 02:22:54.810 --------------------------------------------------------------------------
