SCP - Server unexpectly closed network connection
SocraticBliss
Texas
When attempting to open a tunnel-ed SCP protocol connection, starting with WinSCP 6.4.2 Beta, I immediately receive a "Server unexpectly closed network connection".
I can successfully connect with previous version of WinSCP, I can also connect on the latest version of WinSCP, if I change the Protocol to SFTP (but would highly prefer to have SCP working again).
Tested on the following Portable versions:
6.3.1 | works
6.3.7 | works
6.4.0 (beta) | works
6.4.1 (beta) | works
6.4.2 (beta) | does not work
6.4.3 | does not work
6.5.1 | does not work
6.5.2 | does not work
Attached some logs of the attempts on both 6.4.1 (working) and 6.4.2 (not working)
I even tried compiling the WinSCP 6.4.2 Beta version to attempt to add additional debugging messages, but I'll be damned if I am paying $2400 to simply compile WinSCP (...and yes, I even tried with the latest Community Version 23.0 and ran into compatibility issues while compiling)
  • WinSCP_6.4.1_Redacted.log (43.02 KB, Private file)
  • WinSCP_6.4.2_Redacted.log (24.62 KB, Private file)
SocraticBliss
Thanks for taking a look! Glad to see that you may think that you have a potential solution :)
P.S. Any chance of moving away from needing to use that specific compiler? I would think it could help better maintain things from a long term perspective.
I'm just moving to a new compiler. But I do not think the compiler is the problem. It's rather the IDE/libraries used. And that's unlikely to change any time soon, sorry.
SocraticBliss
Apologies, I guess I was lumping the IDE and the Compiler into one, if the Object Pascal programming language is still needing to be used, that is somewhat unfortunate... (due to the costs required), but I guess somewhat understandable.
SocraticBliss
I noticed that the Issue 2388 – Dropbear SSH server on some devices rejects connection – possibly due to new KEX algorithms, doesn't appear to have a lot of movement... is it still being considered to be resolved?
@SocraticBliss: I believe that this is primarily server-side problem. So it should be resolved on Dropbear side. A workaround on WinSCP side is possible, but only if there's sufficient demand – what is not the case atm. Sorry.
Ok understood, I will let the users know that they should continue to use WinSCP v6.3.1/7 if they want to connect.
Thanks!
SocraticBliss
Texas
I have an update on this issue!
After additional troubleshooting, I found the likely reason why it seems to be working in the older releases...
By default, the Diffie-Hellman group 1 (1024 bit) option is within the --warn below here-- section, then at the Security warning popup, the end user can select Yes and it successfully connects, with the newer versions, the Yes selection on the popup... does not seem to be enough to allow WinSCP to connect.
However... if you move the Diffie-Hellman group 1 (1024 bit) option above the --warn below here-- section and above the Diffie-Hellman group exchange option, it is able to connect without issue!
Would it be possible to still allow the connection if the end user accepts the Security Warning popup?
(Basically, I am trying to have the connection work without the end user needing to go into the settings and moving the Diffie-Hellman group 1 (1024 bit) option, having it work the same way as in previous WinSCP versions.)
Thanks in advance :)
Thanks for the details. So it's probably the order that matters, not the warning. What if you move "group exchange" options below "group 1", so that all are below the warning line? Will the connection work after you confirm the security warning?
SocraticBliss
Texas
Yes I can confirm that when I moved all of the options to below the warn line (Advanced Key Exchange) that a second popup box was displayed (Second Popup) and after accepting it I was able to successfully connect.
  • Screenshot 2026-06-25 091957.png (19.45 KB, Private file)
Description: Second Popup
  • Screenshot 2026-06-25 091439.png (33.6 KB, Private file)
Description: Advanced Key Exchange
Thanks for the test. I'm quite sure it's server-side problem. And I cannot make WinSCP prioritize deprecated insecure algorithms just to make it compatible with your server. You should get the server upgraded. Sorry.
