Windows 11 – WinSCP is constantly redrawing
mitz
My work laptop was updated to Windows 11 late last year and everything was smooth with the exception of WinSCP. On Windows 10, had no issues at all but with 11, the app seems to redraw its windows every 45-60 seconds. I've tried uninstalling and using the winget version, uninstalling that and installing fresh, using the cleanup tool built in, but no luck at all. I've posted a video here since it's too large to attach: https://photos.app.goo.gl/PfGk1oW4Z93f21jx9
I had my personal PC on Windows 11 with no such issue and haven't seen this anywhere else but it's driving me up a wall. Any thoughts on what to do to stop this from happening?
Re: Windows 11 – WinSCP is constantly redrawing
mitz
After a decent amount of troubleshooting, the solution was found. Martin found in the debug logs that something was issuing a refresh fairly frequently stemming from the taskbar.
I have DisplayFusion installed and that has a better multi-monitor taskbar than then one built into Windows 11. That appears to be causing this issue as when I exited from DisplayFusion, the issue disappeared.
Digging into the settings for DisplayFusion, I found an advanced setting called "Disable Hooking the Windows Taskbar". Setting this option made the redraw issue go away. Thank you for the help!
