Upgraded to 3.8.1 - now cannot connect to any host
Hi, I upgraded from 3.8.0 to 3.8.1 and now I cant connect to any host with any settings, I cant connect to the server I had saved in 3.8.0 (and was using 5 mins earlier) and I've tried re-adding it as a new Stored Session. I haven't changed anything else since upgrading and the server is definitely not down.
I upgraded to fix the keep-remote-dir-up-to-date feature so id like to get this working rather than go back to 380. Any ideas?
Re: Upgraded to 3.8.1 - now cannot connect to any host
- oops just to add:
When I caonnect it says 'Searching for host...' and then I get a Connection Timed Out box.
I would suspect some local firewall that checks checksum of the exeutable, thus does not allow the new version to connect.
Good call, I restarted my router and everythings working. Unfortunately now I just upgraded Skype and thats not working :(
