no filetransfer between WinSCP2 and Ensim
phalanx
Ensim makes use of weird usernames to login. Something like user#domain@domain. Because of the -l option one is able to connect with ssh and also with WinSCP to an Ensim server. Filetranfer however doesn't work because scp has no -l option. Is there a solution for this problem so i can make use of WinSCP to tranfer files to an Ensim server?
thank you,
:-pH (peter)
Re: no filetransfer between WinSCP2 and Ensim
I'm sorry, but I dont understand what's your problem. Can you try to explain it once again? Log file can also be useful.
andreso
To use WinSCP in Ensim 3.1* you have to intstall as root two rpms into the domain
you want to use WinSCP for using addpkg: sh-utils and openssh
Do a search for addpkg in forum.rackshack.net and install it to your system. Then as root run:
addpkg domainname.com sh-utils
and
addpkg domainname.com openssh
In the username textbox enter user#domainname.com
The hostname is any hostname that resolves to the ip your domain resolves to
Andres
