Unexpected winscp.exe termination
silvio.ciaccia@gmail.com
Rome (ITALY)
I made a program in .NET where I use the WinSCP assembly and sometimes I get a WinSCP error like in the figure. I attach the WinSCP logs. What causes this error?
  • winScpLog.zip (1.54 MB, Private file)
Re: Unexpected winscp.exe termination
Rome (ITALY)
Hi Martin,
finally I compiled my program with the winscp debugger sent me some days ago. I send you the relative logs after I used the program for a little bit.
Many thanks for your support.
  • winScpLogs.zip (225.81 KB, Private file)
Description: My program opens an external application, but I had a problem to open the application using your debug version. I hope the logs are enough.
Thanks. Though I need the trace logs from the debug build. And mainly trace logs of the crash. I seems that you haven't reproduced the crash with the debug build. Have you?
I do not understand the part about "problem to open the application".
Rome (ITALY)
Hi Martin,
The "problem to open the application" is connected to the crash. My program starts an "application" that creates files. Then I open the connection with the ftp server, copy the files and close the connection. Sometimes I get the files from the server, so I open the connection, get the files and close. The crash is not frequent and it happens after many steps (open/get or put/close). With your debug build I have problem to open the "program" and to try many times the steps.
Thanks for your support.
