WinSCP 6.5.1 GUI issue with folder view
Waruwaru
Deutschland
Since updating to version 6.5.1, my folder panel looks like attached.
Observed issues:
  1. Unusually long lines in the folder view
  2. The arrow (e.g., for the "Intel" folder) is missing when the folder is expanded
  3. The arrow is also not clickable
System: Windows 11 Version 24H2 (Build 26100.3775)
EDIT: I downgraded to version 6.3.7 and all is fine again.
Additional issue with the forum:
The "Preview" button works the first time, but after previewing, I get the following error when trying to post:
General error – Sorry, your post was not accepted. Please, make sure you have JavaScript enabled.
JavaScript is enabled, and the initial preview loads correctly—but after that, preview fails.
Re: WinSCP 6.5.1 GUI issue with folder view
Thanks for your report. Please post your display/monitor setup. Their number, resolution, scaling. Which display is primary one. On which display do you start WinSCP. Thanks.
Thanks. I was able to reproduce the problem now. I'll look into it.
Though I can see the color problem on 6.3.7 too. It's not new in 6.5, right?
Also 6.3.7 seems not to scale the lines at all, so it wasn't really behaving correctly, it just had the opposite problem than the 6.5 has.
