Temp files handling for the "Moving and Duplicating Remote Files"
i3vi3v
I really like that I can do Ctrl+C/Ctrl+V from one "remote" tab (say, FTPS) to another "remote" tab (say SFTP) in WinSCP 6.5. Thanks!
However, recently, I ran into an issue while trying to copy 1TB of files (4GB each) using this feature. It turns out that WinSCP downloads (to a local temp folder) all files from the source first and then moves them to the destination server. The thing is – I only had ~0.5TB free on my C:\ disk.
My workaround was to modify the %TEMP% (and the %TMP%, just-in-case) environment variable, for the WinSCP to use another disk (the one with few TB available).
So, I'd like to suggest the following:
  1. it would be great if WinSCP would just copy files one-by-one (maybe few uploads + downloads in parallel, for better performance), not "download all" + "upload all"
  2. it would be great if WinSCP would have warned me about a lack of space on my local disk before starting that operation
  3. it would be great if this article would document that WinSCP would download all files to the %TEMP% folder instead of saying "without downloading them to local machine".
Re: Temp files handling for the "Moving and Duplicating Remote Files"
Thanks for your suggestion. I'll consider it.
Some notes:
  • You do not need to change global TEMP variable. You can change the temporary location in WinSCP preferences:
    https://winscp.net/eng/docs/ui_pref_storage
  • The documentation says:
    You can also duplicate a remote file to different server using local temporary copy.
