-rawsettings DetachedCertificate -hostkey and Load Authorities from PuTTY
koka
Connect using a certificate with:
winscp.exe sftp://_@127.0.0.1:2200/ /hostkey="ecdsa-sha2-nistp256-cert-v01@openssh.com 256 HGzeMguvVfTsMb+WfkqmjZNXaeVcBXCQqXyjKUBy9pA" /rawsettings DetachedCertificate="C:\Users\user_\.ssh\id_rsa-cert.pub"
is possible if the option Security > Load Authorities from PuTTY is enabled as SshHostCAsFromPuTTY=1 and the host certificate is specified in:
[HKEY_CURRENT_USER\SOFTWARE\SimonTatham\PuTTY\SshHostCAs\X]
"PublicKey"="AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBFDm48o80E2Ah5JFxqRzYzRN5hJx2y1+Pkukace/j1n0aw+6CemCSz2o4T+n7CG9yyneWggyz59eser70VOLI3A="
"Validity"="*"
if you change SshHostCAsFromPuTTY=0
then you will not be able to connect. This is because
-hostkey="ecdsa-sha2-nistp256-cert-v01@openssh.com 256 HGzeMguvVfTsMb+WfkqmjZNXaeVcBXCQqXyjKUBy9pA"
changed SSHManualHostKeys
as
plink -v _@127.0.0.1:2200 -hostkey AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBFDm48o80E2Ah5JFxqRzYzRN5hJx2y1+Pkukace/j1n0aw+6CemCSz2o4T+n7CG9yyneWggyz59eser70VOLI3A= -cert C:\Users\user_\.ssh\id_rsa-cert.pub
and that's right, if it's not a certificate, but if it's a certificate, then you need to change:
[...\SshHostCAs\X]
"Validity"="*"
to connect.
Where PublicKey and Validity from file ~/.ssh/X:
@cert-authority * ecdsa-sha2-nistp256 AAAAE2VjZHNhLXNoYTItbmlzdHAyNTYAAAAIbmlzdHAyNTYAAABBBFDm48o80E2Ah5JFxqRzYzRN5hJx2y1+Pkukace/j1n0aw+6CemCSz2o4T+n7CG9yyneWggyz59eser70VOLI3A=
Re: -rawsettings DetachedCertificate -hostkey and Load Authorities from PuTTY
I'm bit confused. I do not use this much, but the DetachedCertificate is not related to the "Load Authorities from PuTTY", right? The first is about user authentication, while the later is about host authentication.
What are you trying to do? Are you trying to verify certified host key by passing public key of the certificate in /hostkey?
Ok, and does your plink example imply that it is possible with plink to use its -hostkey to specify a public key of the certificate? I do not even thing that plink has any -cert switch.
