TunnelPasswordPlain from named pipes ?
r4dius
I've been running WinSCP with my tool (https://github.com/r4dius/AutoPuTTY/) in command line,
I'm updating it to use named pipes for all passwords but I'm not sure if it's possible with TunnelPasswordPlain, could not find any example of it,
is it working with it or can it be added?
Re: TunnelPasswordPlain from named pipes ?
It should be possible.
Where you are currently setting TunnelPasswordPlain, just replace the password with the path to the named pipe.
