Root Folder download
lascrams
Las Vegas
I've been reviewing different topics on your forum, but I'm stuck on something. I'm working on a script (example below) and trying to download files from the root folder of an FTP host.
I have some log files I can share if needed. Right now, I'm just not sure which command I should be using to download from the root folder. I started looking through the documentation, but I couldn't find the answer.
open sftp://SFTPMIT2005-gmail@fn01.test.com/ -hostkey="ssh-rsa 2048 SHA256:fgrhrtytytyu56487" -privatekey="C:\downloads\test\PrivateKey_PuTTy.ppk"
  "ls" ^
  "get *.* C:\downloads\test\clientA\""" ^
# Disconnect
close
# Exit WinSCP
I would really appreciate any help with this part. Thank you!
Re: Root Folder download
Your code is mixing script file syntax and command-line syntax.
Correct script file syntax would be like:
get /*.* C:\downloads\test\clientA\
See Automate file transfers (or synchronization) to FTP server or SFTP server.
