Bug report: wrong file length in directory listing
abstrv
When the names of several files on server differs only in case the WinSCP shows the same length/time/permissions for all the files.
For example, for the files:
-rw-r--r-- 1 user user 17 May 7 18:22 file.txt
-rw------- 1 user user 4793 May 7 18:34 FiLe.TxT
-r--r--r-- 1 user user 52 May 7 18:25 FILE.txt
WinSCP indicates
file.txt 52 07.05.2003 18:25 r-xr-xr-x
FiLe.TxT 52 07.05.2003 18:25 r-xr-xr-x
FILE.txt 52 07.05.2003 18:25 r-xr-xr-x
Is it a bug or I missed some settings?
Regards,
Alexander
Re: Bug report: wrong file length in directory listing
I have tried this with WinSCP 2.3 and it works fine. What version are you using?
