Scripting a daily 100+ GB upload and keep getting Network errors and timeouts
slamfest
Scripting a 100+ GB upload and keep getting Network error: Software caused connection abort, timeouts, and taking a very long time.
It either retries or sometimes freezes and I have to break out and try again. It does resume where it left off, but can't seem to get it to complete. Any help would be appreciated.
.bat file
rem "C:\Program Files\7-Zip\7z.exe" a "D:\ONEDRIVE\PRM_BACKUP\%DATE:~7,2%.%DATE:~4,2%.%DATE:~-4% Backup".zip D:\ONEDRIVE\PRM_Backup\*.bak
move "D:\OneDrive\PRM_Backup\*.zip" "D:\OneDrive\PRM_Backup\temp\"
"C:\Program Files (x86)\WinSCP\winscp.com" /script="C:\Program Files (x86)\WinSCP\Upload.txt" /log="C:\temp\UploadPRM.log"
if %ERRORLEVEL% neq 0 goto error
echo Upload succeeded, moving local files
move "D:\OneDrive\PRM_Backup\Temp\*.zip" "D:\OneDrive\PRM_Backup\Archive"
move "D:\OneDrive\PRM_Backup\Temp\*.bak" "D:\OneDrive\PRM_Backup\Archive"
forfiles /p "D:\OneDrive\PRM_Backup\Temp" /s /m *.zip /D -2 /C "cmd /c del @path"
exit /b 0
:error
echo Upload failed, keeping local files
exit /b 1
.txt file
;WinSCP script to zip files and upload to SFTP server
; Save this with .txt extension and run with WinSCP.com
option batch abort
; Connect to SFTP server
open sftp://username:password@sftp.domain.com -rawsettings SendBuf=0
bin
; Upload zip file
put "D:\ONEDRIVE\PRM_BACKUP\temp\*.zip"
; Close connection
close
uploadPRM.log is full of these messages
 . 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer
. 2025-04-04 12:20:42.526 There are 56672 bytes remaining in the send buffer, need to send at least another 23904 bytes
. 2025-04-04 12:20:42.526 Detected network event
. 2025-04-04 12:20:42.526 Received 26 bytes
. 2025-04-04 12:20:42.526 Read 4 bytes (22 pending)
. 2025-04-04 12:20:42.526 Read 22 bytes (0 pending)
< 2025-04-04 12:20:42.526 Type: SSH_FXP_STATUS, Size: 22, Number: 7182854
< 2025-04-04 12:20:42.526 Status code: 0
. 2025-04-04 12:20:42.542 Detected network event
. 2025-04-04 12:20:42.542 There are 56672 bytes remaining in the send buffer
. 2025-04-04 12:20:42.542 There are 56672 bytes remaining in the send buffer, need to send at least another 23904 bytes
. 2025-04-04 12:20:42.542 Received 26 bytes
. 2025-04-04 12:20:42.542 Read 4 bytes (22 pending)
. 2025-04-04 12:20:42.543 Read 22 bytes (0 pending)
slamfest
Re: Scripting a daily 100+ GB upload and keep getting Network errors and timeouts
Attached
  • UploadPRM.log (3.2 MB, Private file)
I do not see any "Network error" in the log.
I can see that you are setting SendBuf=0. Are you doing that to avoid the network errors?
Any chance of getting a test account of the server?
slamfest
Not "Network Error" specifically, but "Detected network event" and it times out and goes very slow. I wouldn't think it is normal to see such small byte transfers over and over in the log, but I am not an expert here.
Received 26 bytes
After researching my issue I tried SendBuf=0, but I don't know if it is helping or hurting.
Unfortunately I cant provide you access to that server. It has protected information.
I do not see any timeout either.
I do not need to access any information. Just an empty account with some storage for upload testing.
