Can't access the file or directory error. LIST -a command
Magda
Poland
Hello I am using WinSCP .NET assembly 6.3.7 in Visual Studio 2022 VB. I have issues with getting file from FTP server to local directory, foulting with errors:
Can’t get attribute of file, Could not retrieve directory listing, Can’t access the file or directory.
File is stored at A:/Listy/ directory on FTP server. File exist in the server – I am trying to get Lista9.csv.
I monitored the communication with Wireshark, please find loggs attached
-What exactly is LIST –a command, the response for this command is : Can’t access the file or directory. Than - even if the current directory is A:/Listy/ the program is trying to go to Listy again - with no success. Please check attachment. Is there a way to provoke some other listing command to the FTP server?
BR
Magda
  • Log.txt (39.45 KB, Private file)
  • List -a with WinSCP.docx (241.51 KB, Private file)
Re: Can't access the file or directory error. LIST -a command
The correct path to the file seems to be A:/Listy/Lista9.csv. So use that in Session.GetFileToDirectory call. If that does not help, please post session log file (not the debug log).
Magda
Poland
Reply
Please find session logs with command session.GetFileToDirectory(GetFileFromPath, DestPath)
Dim GetFileFromPath As String = "A:/Listy/Lista9.csv"
  • SessionLog.xml (955 Bytes, Private file)
  • Log.txt (40.16 KB, Private file)
  • print_wireshark.docx (324.24 KB, Private file)
Magda
Poland
File for session.SessionLogPath
Sorry, now right log is attached.
  • SessionLog.txt (12.3 KB, Private file)
