The server's certificate is not known
srs44
WinSCP version 6.3.7
When I use WinSCP command line:
winscp.com /command "open ftpes://zzzz1:ZZZzzzz%23%2F@Tools-n-Gizmos.com/"
Progress window =
Connecting to Tools-n-Gizmos.com ...
TLS connection established. Waiting for welcome message...
Connected
Starting the session...
Session started.
Active session: [1] zzzz1@Tools-n-Gizmos.com
winscp>
When I run script:
Progress window =
The server's certificate is not known. You have no guarantee that the server is the computer you think it is.
Server's certificate details follow:
Issuer:
- Organization: Let's Encrypt, R11
Subject:
- Organization: agora.serverg.net
Valid: 1/21/2025 2:52:21 PM – 4/21/2025 2:52:20 PM
Fingerprints:
- SHA-256: bb:8d:25:99:c6:e1:fb:7f:98:4f:12:a1:a1:9a:dc:6b:83:df:b4:e8:7c:b2:20:dc:f4:c1:94:52:1e:cc:33:40
- SHA-1: e9:0e:26:00:9e:e0:72:3f:13:b5:4d:9b:4d:a1:4c:12:d9:6b:1e:18
Summary: Unable to get local issuer certificate. The error occurred at a depth of 2 in the certificate chain.
Certificate was not issued for this server. You might be connecting to a server that is pretending to be "Tools-n-Gizmos.com".
If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
Continue connecting and store the certificate?
(Y)es, (N)o, C(a)ncel (4 s), (C)opy Key:
If I press y then I get successful connection:
Connected
Session started.
winscp>
But WinSCP does not store the trusted certificate and everytime I run the script it hangs waiting for manual approval.
Re: The server's certificate is not known
srs44@...
I would love to provide a full session log file. But I can't get the log function to work.
I'm calling my script from Excel macro using the following, which works great and uploads files.
Call Shell("""C:\Program Files (x86)\WinSCP\WinSCP.com"" /ini=nul /script=""D:\$_My Stuff\@_Griz44\@Working\_Griz44\_Development\UploadScript.txt"" ")
When I add /log=C:\WinSCP.log switch, the script does not run correctly and no files are uploaded.
Call Shell("""C:\Program Files (x86)\WinSCP\WinSCP.com"" /log=C:\WinSCP.log /ini=nul /script=""D:\$_My Stuff\@_Griz44\@Working\_Griz44\_Development\UploadScript.txt"" ")
And no logfile is created
On Windows, you typically do not have write access to a C:\ root. Did you try other path?
srs44@...
Whoops, D:\ worked.
I will now put together a session with logfile of my connection "server certificate is not known" problem and get back to you.
srs44@...
Ok, attached are 3 scripts and 3 log files
#1 is successful connection using -hostkey="*" switch which I'm using to refine my huge Script.
#2 is my original Script without -hostkey switch
#3 is one on many attempts I've made trying to provide the proper signature. Most likely I have a syntax problem but the solution is beyond me.
In general, you indeed should specify the certificate fingerprint using the -certificate switch (the -hostkey works too, but it's semantically incorrect). That's because the scripts should better run in isolated environment, not relying on certificate caches.
But in your commandline in your first post, you didn't use /ini=nul. So the caching should have worked. But now in the log I see that you actually use /ini=nul. That explains, why caching does not work.
As for the syntax: The SHA-256: prefix shouldn't be there.
So it should be like:
open ftpes://user:pass@Tools-n-Gizmos.com -certificate="bb:8d:25:99:c6:e1:fb:7f:98:4f:12:a1:a1:9a:dc:6b:83:df:b4:e8:7c:b2:20:dc:f4:c1:94:52:1e:cc:33:40"
