Limitations of dragging / moving files in WinSCP
Shrinivas
Hello ,
I am IT working for a firm and one of our WinSCP users drags files into the inbound folder on WinSCP, there is always a maximum of 3 files that get accepted unto TRAX while the other files does not get accepted.
I then updated the WinSCP version to the latest which is 6.3.7 and then tried and it took 5 files and not the rest.
Hence is there any limitation to drag the file into the inbound folder on WinSCP or is there any settings / steps that needs to be changes within.
Request your assistance. Thank You,
Shrini
Re: Limitations of dragging / moving files in WinSCP
What does it mean "not get accepted"? Do you get any error? What error? Can you post a log file? Do you get the problem when dragging the files only? Or even when uploading using commands/menu?
Hello – Thank you for replying
File attached of the issue that the user is trying to drag from the left onto the right
The user tries to select documents at once and then drag it onto the right, but only 3 documents gets copied over while the rest does not. Other members in her team is able to successfully do it accept her, hence wanted to know if there is any settings within.
As I have asked above, please attach a full session log file showing the problem (using the latest version of WinSCP).
