SFTP login works from one WinSCP client, but fails with Access Denied from another WinSCP client
bfin
Same version of WinSCP 6.3.7 on 2 laptops. One is Windows 10, the other is Windows 11.
Win10 connects to a Remarkable2 tablet with no problem.
Win11 fails with a "Access Denied" on the password prompt.
Neither systems has the Windows default SSH (OpenSSH) client.
I've deleted the cache, checked that the configuration settings on each laptop are the same.
Any ideas on where to look?
Re: SFTP login works from one WinSCP client, but fails with Access Denied from another WinSCP client
Please attach a full session log files from both machines.
bobfin
Upgraded to equal versions. Verified that the passwords being used on both system are identical. I've got no logging from any firewall/AV type software. Also checked the Windows Event Viewer and there are no errors or information logged when I try to connect and log in.
Strange.
I'm going to dig into the SSH server – a Remarkable2, and see what I can find there. Seems like WinSCP is working fine.
